SMS Notification Ringtone ... No Sound?
This is a discussion on SMS Notification Ringtone ... No Sound? within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hello, [I SEARCHED! Found nothing, apologies if this is a repost.] New user here, overall VERY satisfied with this device (even though no 3G, coming ...
Results 1 to 10 of 11
Thread: SMS Notification Ringtone ... No Sound?
    Member davidlm's Avatar
    Hello,
    New user here, overall VERY satisfied with this device (even though no 3G, coming from a BB Bold 9000). Small issue: MAYBE I'm going insane, but I SWEAR that sometimes when I get an SMS my phone does make a sound. I'll look down and see the trackball lighting up so I'll know I have a notification of some sort and will see it's an SMS when I look at the notification bar. It doesn't seem to be doing this for Emails or any other sort of notification. Is anyone else having this problem? Thanks in advance.
    You will have to go into the apps that you want to notified on, through the settings. i.e messaging, SDcard email etc!
    Bishop6, I think I understand what you're saying and I do have SMS notifications set to ringtone. It normally makes a sound when I get an SMS.
    Right, so open say messaging, then settings and you will find an option to notify you...
    The same for every other app that you want a notice on.
    Yea I've done that ... Hmmmm
    With the notification, you also have to set a ringtone or vibrate / both.
    I have it set to both ...
    Junior Member AnotherN1's Avatar
    I have had the same problem ever since I got my Nexus one.... Solution is to reboot the system. However, I am very close to returning my device as I do not want to be stuck with a defective product as this sound issue might be a precursor for some other problem
    FYI, this has yet to happen to me since my original post.
    It appears that you have done everything, you may have to do a couple of resets...
    1) Turn off the Nexus, remove the battery for a couple of minutes; then reinstall and power up then see if that helps.
    2) If '1' doesn't work, it's a long shot; but you may have software issue and a factory reset will fix it.
    If you go with 2, as a rule... back up everything!!
android notification sound stuck
no ring tones for go sms
samsung galaxy no ring back sound
