nexus one wont send long sms messages
This is a discussion on nexus one wont send long sms messages within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Searched the forum and couldn't find any post like mine. When its a long SMS message the icon just says sending but will not send ...
Thread: nexus one wont send long sms messages
    Junior Member fatfei's Avatar
    When its a long SMS message the icon just says sending but will not send even after five minutes. I don't receive any errors. I have herd of problems with nexus one messaging. Am using 02 network in the Uk.
    Quote Originally Posted by fatfei View Post
    Maybe it's something to do with your carrier, as the Nexus will send short or long sms, however if the sms is over a certain amount of characters; it will split the message before it's sent to the receiving end.
    I don't it's a Nexus issue.
    Also try Handsent to see if it's a limitation of the native app.
    What's handsent and how do I use it?
    Junior Member onenexus's Avatar
    That's OK. I found it in the end. Thank for the help
