Battery Drain Problem...It's fixed. (workaround)
This is a discussion on Battery Drain Problem...It's fixed. (workaround) within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I read some posts on the web and here and tried the following. Today i have a full battery bar (about 85% full). It usually ...
Results 1 to 10 of 10
Thread: Battery Drain Problem...It's fixed. (workaround)
    Junior Member zohan30's Avatar
    I read some posts on the web and here and tried the following. Today i have a full battery bar (about 85% full). It usually drops down to 5% and I had to charge every day.
    Here are the steps.
    Download Advanced Task Manager and install
    Download Handcent (for messaging) and install
    Set handcent to be default messaging.
    Run advanced task manager and kill the default messaging app provided by HTC.
    This is a workaround for the battery drain problem until google/htc address the issue.
    Senior Member dixy2k's Avatar
    What happens if you use Google Voice for SMS?
    Would GV run in the background too?
    I am not sure about GV and messaging. But as long as you kill the default Messaging (the green robot picture) from advanced task manager, you are on your way to fuller battery and not charging so often.
    Without Advanced Task Manager the app cannot be shut down? There is no way to quit the app from the phone's menu?
    Senior Member techiegirl's Avatar
    I thought all you had to do was turn off the default messaging app's notification.
    turning off the notification only turns of the notification bar if you get messages. the messaging app still is running. So whenever i turn off/on the phone, i just kill the messaging app. today, with full screen and bluetooth, i had 50% juice towards the end of the day. (lots of txt messaging and also 30 minutes of phone calls)
    Member insomnium's Avatar
    this worked for me, been using handcent for a few weeks now.
    i do notice the battery lasting longer...
    Do you have to kill the default messaging app every time you turn the phone on?
    I do kill the app once I turn on the phone. It's a quick process. Note that this is just a bandaid to remedy the battery drain until HTC/Android address the battery problem.
    Also, I disabled Gtalk since I don't use their chat. Go to Talk (Gtalk) and click Menu and turn off Auto Run.
    Android Lurker Cubanito's Avatar
    Quote Originally Posted by zohan30 View Post
    Here are the steps.
    Dont really have a problem with battery usage myself but thanks for the heads up on handcent! awesome messaging app!!! thanks.
  1. Epic 4G Root Thread
android glgps
android glgps battery
battery drain surfaceflinger
glgps
glgps battery
glgps battery drain
glgps nexus 7
surface flinger battery drain
surfaceflinger android battery
surfaceflinger android battery drain
surfaceflinger battery
surfaceflinger battery drain
surfaceflinger draining battery
what is glgps
what is glgps android
