APN Settings Help !!!!!!
This is a discussion on APN Settings Help !!!!!! within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Originally Posted by ovigt71 Originally Posted by soongteck Originally Posted by ovigt71 still doesn't work. i was following your instruction, but........ any other advice? i ...
Results 11 to 20 of 21
Thread: APN Settings Help !!!!!!
    Member soongteck's Avatar
    Quote Originally Posted by ovigt71 View Post
    Quote Originally Posted by soongteck View Post
    i feel sorry for your mms problem.
    as my first time in setting up mms also have this kind of issue.
    maybe you should try this:
    1. delete all apn, restart phone, reset the GPRS/MMS
    make sure your GPRS apn type is default (internet data will have radio button besides)
    mms apn type is mms (there will be no radio button/circle besides this apn)
    2. if it is ok for you, you might wanna try to hard reset your phone once and reset the apn.
    how you reset GPRS/MMS on N1?
    delete all APN from your list, restart your phone, and create those apn back
    Junior Member ovigt71's Avatar
    delete all APN from your list, restart your phone, and create those apn back[/QUOTE]
    done already. this APN is working :
    this one, still not working
    trying to send a MMS, I got 3G icon on notification bar (see on top), but the MMS it doesn't go anywhere.......
    I had trouble with my MMS setting when I was in the UAE as well. Employees at Etisalat were not much of help either.
    problem solved. those two APN can't work together in the same time. In order to use MMS all you have to do is to delete APN Etisalat (for internet 3G).....unfortunately .... now if I want to use Internet I have to edit APN again, but MMS it will not work unless I'll deleted again. So sad.....
    Junior Member Dazzadubai's Avatar
    Hi all. I just bought my Nexus One and I'm so excited. Unfortunately I'm facing with a real problem: I can't figure out how to setup APN for MMS. For internet was easy. My Carrier is Etisalat and I am leaving in United Arab Emirates. I have also HTC Hero and Mototrola Milestone and I have the following settings:
    APN: mms
    username: mms
    password: mms
    MMSC: http://mms/servlets/mms
    MMS Proxy: 010.012.000.030
    MMS Port: 8080
    APN type: mms
    Works brilliant, but with Nexus it doesn't.
    Hi, you say that it was easy setting up internet on your nexus with etisalat. Can you let me know how you did it?
    APN: mms
    username: mms
    password: mms
    MMS Port: 8080
    APN type: mms
    but, I didn't set internet APN..... and I root-ed.......I don't know if is matters or not....
    Junior Member yoshaw's Avatar
    YES I have both APN's for 3G and MMS working at the same time.
    Yes, BOTH work at the SAME TIME!
    (sorry for caps, I'm excited too)
    Kindly use the following link to make your settings for Etisalat. Don't use the first setting at the top. The other two are what I used.
    Carrier APN Settings - ModMyGPhone Wiki
    Here they are just in case that link above doesn't work
    For 3G----------------
    Name: Etisalat3G (can chose any name)
    APN: Etisalat.ae
    -<none>
    -<none>
    -<none>
    -<none>
    -<none>
    -<none>
    -<none>
    -<none>
    MCC: 424
    MNC: 02
    APN type: default
    For MMS----------------------
    Name: EtisalatMMS (chose any name)
    APN: mms
    Port: 8080
    Username: mms
    Password: mms
    -<none>
    MMS proxy: 010.012.000.030
    MMS Port: 8080
    MCC: 424
    MNC: 02
    APN type: mms
    thanks
    thanks. it works!!!!
apn settings for du
du 3g settings for android
du apn
du apn for android
du apn setting
du apn settings
du apn settings android
du apn settings for android
du gprs manual settings
du internet setting
du internet setting for android mobile
du internet settings
du internet settings for android
du mms settings android
du net setting
