APN Settings Help !!!!!!
This is a discussion on APN Settings Help !!!!!! within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi all. I just bought my Nexus One and I'm so excited. Unfortunately I'm facing with a real problem: I can't figure out how to ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: APN Settings Help !!!!!!
    Junior Member ovigt71's Avatar
    Hi all. I just bought my Nexus One and I'm so excited. Unfortunately I'm facing with a real problem: I can't figure out how to setup APN for MMS. For internet was easy. My Carrier is Etisalat and I am leaving in United Arab Emirates. I have also HTC Hero and Mototrola Milestone and I have the following settings:
    APN: mms
    username: mms
    password: mms
    MMSC: http://mms/servlets/mms
    MMS Proxy: 010.012.000.030
    MMS Port: 8080
    APN type: mms
    Works brilliant, but with Nexus it doesn't.
    Quote Originally Posted by ovigt71 View Post
    APN: mms
    username: mms
    password: mms
    MMS Port: 8080
    APN type: mms
    Try these settings...
    APN: du
    MMSC: http://mms.du.ae
    MMS Proxy:010.019.018.004
    MMS Port: 8080
    Username: <none>
    Password: <none>
    Bishop6
    thanks a lot, but I'm not on DU. I'm on Etisalat......do you have something for Etisalat?
    How about...
    APN: mnet
    Username: mnet
    Password: mnet
    if not try
    APN: etisalat.ae
    Username & Password: <blank>
    How about...
    if not try
    APN: etisalat.ae
    this setting is working but is only for internet 3g. mms still not working ......
    Member soongteck's Avatar
    APN: mms
    username: mms
    password: mms
    MMS Port: 8080
    APN type: mms
    can you try to set the authentication type to PAP or CHAP?
    perhaps u can try delete the apn before u reset.
    the proxy u can use this: 10.12.0.30
    still doesn't work. i was following your instruction, but........ any other advice?
    I found this for non supported phones...
    Manual settings for MMS (for unsupported handsets)
    Bishop6
    i feel sorry for your mms problem.
    as my first time in setting up mms also have this kind of issue.
    maybe you should try this:
    1. delete all apn, restart phone, reset the GPRS/MMS
    make sure your GPRS apn type is default (internet data will have radio button besides)
    mms apn type is mms (there will be no radio button/circle besides this apn)
    2. if it is ok for you, you might wanna try to hard reset your phone once and reset the apn.
    Quote Originally Posted by soongteck View Post
    how you reset GPRS/MMS on N1?
apn settings for du
du 3g settings for android
du apn
du apn for android
du apn setting
du apn settings
du apn settings android
du apn settings for android
du gprs manual settings
du internet setting
du internet setting for android mobile
du internet settings
du internet settings for android
du mms settings android
du net setting
