Question about power button
This is a discussion on Question about power button within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi. I was just wondering if anyone else was having problems pressing the power button. It's sitting almost flush with the top of the phone ...
Thread: Question about power button
    Junior Member bkc's Avatar
    Hi. I was just wondering if anyone else was having problems pressing the power button. It's sitting almost flush with the top of the phone so it's hard to press down. It doesn't click like the volume buttons. I'm wondering if that's a defect or if that's the way it's supposed to be. Thanks.
    Quote Originally Posted by bkc View Post
    It's sounds about right to me, I have to use my nail to press it on / off.
    As long as it works... your fine.
    Senior Member dg36's Avatar
    They're all about flush with the edge.... with no click. If it had a clicking mechanism it wouldn't last as long as the simple pressure switch!
    Mine sticks out even more than the volume rocker. I mean it sticks out a good bit. I am. Curious to see more feedback on this.
