Phone won't vibrate!
This is a discussion on Phone won't vibrate! within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; My phone won't vibrate when I get a new text and it's on "vibrate". However, I still feel the shake when I unlock the phone. ...
Results 1 to 10 of 11
Thread: Phone won't vibrate!
    Junior Member Sergio_nexusone's Avatar
    My phone won't vibrate when I get a new text and it's on "vibrate". However, I still feel the shake when I unlock the phone. Anyone know what could be wrong?
    EDIT: It still vibrates when I get a call. :S
    Are you using a third party SMS app or just the stock?
    Just the stock.
    Not sure then really. I'm not sure if you're willing to give this a try but try Handcent SMS app from the Market. It's quite an upgrade over the stock application. Turn off all notifications on your stock SMS app after Handcent is installed (or else you get double notifications) and see if vibrate still works on Handcent.
    Junior Member typingduck's Avatar
    Hey Sergio,
    It's not obvious, but you can set vibrate under settings within the Messaging application itself.
    Junior Member askulah123's Avatar
    Have you set the vibrate on the 'SMS' settings? You need to set it there to vibrate. Setting it on the 'Sound & Display' doesn't work on SMS
    Junior Member brbubba's Avatar
    Yep, that's it. Totally dumb that the system settings can't override any other settings. Why even have them there? Grr.
    Lightbulb
    Quote Originally Posted by brbubba View Post
    Actually, it makes far more sense for individual applications to override the global settings. Global settings (in just about any system) are "defaults". Then, you set your various applications to provide fine tuning.
    Junior Member alyssa_nexusone's Avatar
    Quote Originally Posted by askulah123 View Post
    How do you do this?
    I have a Nexus s 4g
    Open your messaging app, hit menu then settings, then notifications, set your vibrate options and enjoy! xD
android phone won't vibrate
galaxy s4 won't vibrate
google nexus s doesn't vibrate
google nexus s wont vibrate
htc one s phone wont vibrate
htc one s wont vibrate
htc one sv won't vibrate
htc one vibrate won't work
htc one wont vibrate
modded android wont vibrate
my galaxy centura wont vibrate when i get texts
my htc one won't vigrate
my phone is set to vibrate but wont vibrate
phone wont.vibrate when ts locked.and i get a text
