3g to wifi auto switch after update
This is a discussion on 3g to wifi auto switch after update within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Before the update, if I switched on the wireless it would dutifully auto connect to a known access point and switch of the 3g connection. ...
Thread: 3g to wifi auto switch after update
    Member tribz's Avatar
    Now when switching on wifi, it stays sitting at the 3G connection and I have to go into my list of wifi networks and connect that way.
    I use wifi buddy and I've uninstalled and re-installed it.
    Anyone know how I can get it back to its original behaviour?
    ive un installed wifi buddy and its returned to normal so must be wifi buddy. ill drop them a line.
    Senior Member flow's Avatar
    well, many issues on the phone in fact causing by rooting or application.. Good to reset the phone first to verify they are the issue.
    Ouch, I'd rather not reset and have to install my apps and settings again. Think I'd initially try uninstalling some of the apps before resetting.
    Junior Member fiatowner's Avatar
    My N1 has never managed to gracefully switch between 3G and remembered wifi spots, neither before nor after the update. Are you guys using wifi buddy to facilitate this?
  1. Is Samsung goiung to fix bluetooth???
    Last Post: 09-19-2010, 03:07 PM
automatic switch between wifi and 3g android
automatic switch from wifi to 3g
htc one automatic switch from 3g to wi fi
wifi android auto connect behaviour algorithm
