Can't connect Nexus One to Sony Gigajuke with USB cable.
This is a discussion on Can't connect Nexus One to Sony Gigajuke with USB cable. within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I would like to transfer music from my Nexus One phone to a Sony Gigajuke NAS-E300HD using the USB cable supplied with the Nexus One. ...
Thread: Can't connect Nexus One to Sony Gigajuke with USB cable.
    Junior Member matt_nexusone's Avatar
    I have connected the Nexus one, mounted the USB drive when prompted but the Giga Juke still says "No Device".
    I've checked the documentation from Sony and they specify that the connected drive must use FAT32 format which it is.. Any ideas??
    4 times
    I believe alpa is right on target there...
    Nexus One 'OS' is not the same format as Ipod, MP3 Player etc. therefore because the USB only allows for media connections; Nexus will not be recognized by the Sony device.
    As alphawave7 mentioned, your best bet will be to try wireless!!
  1. Epic 4G launches August 31 for $249
    Last Post: 09-02-2010, 08:59 PM
