SMS - Auto Capitalization Issue
This is a discussion on SMS - Auto Capitalization Issue within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Since I am taking time to post all these new bugs I've noticed from getting the new update. Here is another one but rather annoying ...
Results 1 to 9 of 9
Thread: SMS - Auto Capitalization Issue
    Junior Member thefilmguy's Avatar
    Question SMS - Auto Capitalization Issue
    Since I am taking time to post all these new bugs I've noticed from getting the new update. Here is another one but rather annoying one that I always have to correct.
    Try this on your Nexus One.. Type a message like the following:
    "how are yoy". Now I have auto caps off to test this but the predicted word comes up You with the Y in caps..... why? Why google? I didn't type a period yet. Now it's just not this word, it's many other words that do this when there is no period present and I just look like an idiot with all of these capitalizations.
    Is anyone else getting this?
    Junior Member spidermonkeyrob's Avatar
    I just turn off autocomplete. It's much less annoying, now.
    Well that's why I said I turned it off to see if this resolves the issue. It doesn't.
    I didn't know you turned off autocomplete. You said you turned off auto-caps.
    Scratch that, I misread. I could try turning off the auto complete but due to stubby thumb syndrome, I need it. lol
    When I saw the option to turn off autocomplete, I was very leery about turning it off. I decided to try it and typing is much less of a headache. It still gives you the row of words to select from at the top of the keyboard, but it just doesn't autocomplete if you hit space or a punctuation mark.
    The main thing I noticed is with the a word like "OK" I type it in Ans it auto capitals both letters. I learned to check what word is being highlighted in the run below and click the right one
    Android Lurker maris's Avatar
    I see this, too, however ... if I select the word it actually enters it correctly (capped/not capped) on the line. It doesn't seem to matter which way it appears in the predictive text, the right one shows up in my sentence.
    I just checked my Android Keyboard settings and I have auto-capitalization, quick fixes, show suggestions, and auto-complete all turned on.
    Quote Originally Posted by Maris View Post
    So are you saying when you type out "yoy" and you hit space it automatically inputs the lowercased "you" instead of "You"?
android capitalization problem
auto correct, capitalization on sms
auto-capitalization android programatically
gosms autocapitalization
how to disable auto capitalization on htc inspire
how to turn off auto capitalization on htc one
htc inspire auto capitialization
when typing gosms all words get capitalized
