phone sync issue
This is a discussion on phone sync issue within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; i tried searching but really couldnt find anything on this, but is anyone having an issue where your n1 doesnt sync with any email including ...
Thread: phone sync issue
    Senior Member deel's Avatar
    phone sync issue
    i tried searching but really couldnt find anything on this, but is anyone having an issue where your n1 doesnt sync with any email including gmail and fb, and when you do a manual sync or refresh it says something to the effect like, cant connect? i find ive been having this issue after a couple days the phone runs fine, but then it seems like after leaving it on for a while, it's like memory is leaking or something. i have a task killer installed and it still doesnt resolve the issue, the only thing that works is a battery pull, and then when it turns back on, everything syncs and is back to normal and i receive all notifications
    Quote Originally Posted by deel View Post
    If it says it "can't connect" that would lead me to believe there's a network issue... check to see if you are able to browse when the problem occurs, it maybe a software glitch with the Nexus which a factory reset may be the answer, (last resort though).
