phone shows no signal when there is?
This is a discussion on phone shows no signal when there is? within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I have good signal at home, but one day I found the phone was showing "no signal" all the time. With knowing there should be ...
Thread: phone shows no signal when there is?
    Junior Member telesky2002's Avatar
    I have good signal at home, but one day I found the phone was showing "no signal" all the time. With knowing there should be signal, I suspected something was going on with the phone. I turned it off and then turned it back on, without any surprise, it showed full signal again. This is REALLY BAD. And it happened at least 2 times after that, and once in those 2 times, when I was trying the usual trick to turn it off first, it freezed and I had to disconnect the battery.
    Quote Originally Posted by telesky2002 View Post
    Are you using 3G and also has your Nexus been update either OTA or manually? it may be an issue with your phone being on 3G and losing the connection and trying to lock onto the 'Edge'.
    If you look into the search forum, there is a good write up on similar network problem.
android phone no signal
android phone shows no signal
android phone turning on and off with no signal
android smart phone shows network but no signal
droid charge showing no signal
nexus 4 showing no signal
nexus one no signal
nexxus phone showing no reception
no signal android phone
no signal on android phone full battery
no signal showing triangle android phone
phone showing no signal
phone showing no signal for no reason
phone showing no signals
