sms 4-digit sender
This is a discussion on sms 4-digit sender within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I have problems with display of sender number and receiving messages from 4-digit sms services. I have also tried the Handcent application with the same ...
Results 1 to 8 of 8
Thread: sms 4-digit sender
    Junior Member eoestlyn's Avatar
    sms 4-digit sender
    I have problems with display of sender number and receiving messages from 4-digit sms services. I have also tried the Handcent application with the same result as the inbuilt message application.
    The first part of the message is used as the sender address and subtracted from the message. When the message only contains one word, the message process terminates unexpectedly.
    It is impossibel to answer the message using the detected adress. All other sms messages works ok.
    Senior Member elvis1's Avatar
    buggy phone!!
    Gee Elvis, that was helpful. Are you trying to say that the Nexus One is buggy, or the user's particular phone has a problem?
    In Norway there are many automated VAS services identified by a 4 digit number. All of these services malfunctions. Only inbuild message application terminates, handcent deliver message, bus does not identify the sender.
    4 times
    Handcent can also blacklist them....
    Blacklisting is not a solution, I want the message received correctly formatted and withh correct sender identified like all other phones do. Handcent is better than standard message application since it doesn't terminate. It seems like android 2.1 sms plattform does not deliver correct sender address in the case of 4-digit numbers.
    4 times
    Oh, Sorry I miss-understood ya.
    Junior Member tomvb's Avatar
    I have the same issue. It has been reported at the official issue tracker. You might want to "star" that issue, so that it climbs higher in the list.
4 digit sms
4 digit sms code
4 digit text message as sender
4 digits code identifying the sender of a text message
android text from 4 digit number
bill shows text to 4 digit
four digit text
messages with four digit numbers as the sender
sms 4 digit code
sms from 4 digit number
sms from 4 digit numbers
sms text sender four digit number
sms to four digit number help ???
sprint 4 digit sms codes
text message with the four numbers sender code
