Nexus does not go past boot screen
This is a discussion on Nexus does not go past boot screen within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; oh wait, this thread is rather old. @eparedes7, can you please list what you need help with specifically, so you can be helped?...
Results 11 to 16 of 16
Thread: Nexus does not go past boot screen
    Nexus One and luvin it
    Rooted 5/6/2010
    Enomther 2.10.1 Froyo Release
    Junior Member eparedes7's Avatar
    thanks dude. i notice i am not rooted and i will try the bootloader.
    Quote Originally Posted by dimmakherbs View Post
    when the phone is 'seen' but not recognized, it usually means you havn't installed the drivers.
    open your SDK and go to go under 'packages to install' select them ALL and update, hopefully that gets them all.
    see if that helps.
    volume down and power gets you to HBoot / Bootloader.
    trackball and power gets you to Fastboot.
    these are seperate so don't press all 3 as it gets confusing on where you went to.
    I am not 100% certain, but fairly sure that if you can use the trackball and power to get to fastboot you are rooted. However, it doesn't matter because whether you are in either of those screens you will have a magenta "*** UNLOCKED ***" in the very top.
    I think it may be best to find out if you are rooted or not before continuing because that will take a seperate path of steps. You should easily be able to download a ROM and recovery on your SD card and run the recovery from fastboot and then flash a ROM and get you back going.
    well i thought is this was a similar issue that i was having .
    but my nexus one does not pass, the nexus one symbol.
    is this a different problem?
    Quote Originally Posted by eparedes7 View Post
    can you start from the begining on your problem?
    what happened before this started? i see you are not rooted, so that answers that. Are you not getting passed the static symbol or not getting passed the animated shooting X symbol?
    Rooted 5/6/2010
    i not getting pass the static X symbol.
    Junior Member deen_03's Avatar
    I just had the same problem with mine when i tried to install the 720p upgrade my work around was to remove the sd card and reinstall the frf50 froyo as an "update" to my phone and it worked try that if you haven't solved it already
  1. Galaxy s power pack...
    Last Post: 10-28-2010, 12:08 PM
can't get nexxus 7 to go past google start up
my android does not go past the start up screen
my galaxy nexus doesnt pass from start up screen
nexus 4 will not go past google start up
nexus 4 will not go past start up screen
nexus 7 android banner will not boot
nexus 7 will not boot past the google screen
nexus 7 will not boot past x
nexus 7 will not start past google banner
nexus does not get past google screen
nexus one stuck at boot screen
nexus will not go past boot screen
nexus will start but not go past boot up screen
nexus7 will not go past the x
samsung nexus 10 will not pass boot
