Having trouble pulling up contacts when directly messaging.
This is a discussion on Having trouble pulling up contacts when directly messaging. within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi everyone, This is my first post on these forums. I am having a problem attempting to easily access my contacts when going staight to ...
Thread: Having trouble pulling up contacts when directly messaging.
    Junior Member rebenga's Avatar
    Hi everyone,
    I am having a problem attempting to easily access my contacts when going staight to "MESSAGING"
    The way I now need to find people to text is to go to "PHONE" > "CONTACTS" > Then find my contact > Then select text messaging.
    If I go straight to my "MESSAGING" quick link, then "COMPOSE NEW MESSAGE" .... When I start typing in the address field, no contacts pop up. So if I were to try to text "Mathew" I should be able to type in the letter "M" and all of my "M" contacts should come up correct?
    Any ideas?
    Member floridasrt's Avatar
    Strange, if I go into the "To" field and start typing a name it has a drop box with the name of the contact. I noticed you do have to type 2 letters in for it to search.
    Quote Originally Posted by rebenga View Post
    Hi everyone,
    Any ideas?
    IIRC, contacts require a mobile phone number field to be populated to be included in the SMS dropdown lists. Check that, and g'luck!
    Wow, you are exactly right.
    Now do you know a way to change all of my contact's phone numbers from "OTHER" to "MOBILE"?
    This is going to suck with 200 contacts.
    Junior Member Juice_Boxx's Avatar
    this is my 1st time posting, just got my N1 today! excited =]
    i was getting tired of my iphone :X
    but yeah this was my main concern but this definitely solved the problem!!
    but yes, it would be A LOT easier if there was an option to change all the numbers to "MOBILE" instead of "OTHER"
    Junior Member silverto's Avatar
    Anyone solving this?
    So is anyone solving this? Do we need to do it manually?
    Quote Originally Posted by silverto View Post
    The solution is another textmessenger!
    Junior Member Sean76_nexusone's Avatar
    Hey Guys, anyone find a fix for this?
  1. Football Fans?
    By Epic Forums User in forum Off-Topic Forum
    Last Post: 08-05-2010, 03:21 PM
android device not pulling up contacts when trying to text
galaxy s4 text not pulling up contacts
having issues pulling up the usage reports
