Light Sensor in a dark room issue?
This is a discussion on Light Sensor in a dark room issue? within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I've noticed something and i'm wondering if anyone else has had this issue. I was laying in bed with the lights out talking on the ...
Thread: Light Sensor in a dark room issue?
    Senior Member ScottyPimpin's Avatar
    I was laying in bed with the lights out talking on the phone the past 2 nights. Each time i moved the phone away from my head to put the call on speaker so i could look something up on the phone.. Well when i move it away from my head the screen lights up for a split second then turns off. After a couple seconds it will either flash on/off again or stay on.
    It seems like the light sensor is confused and doesn't know if it's against my head or not during the call because the room is so dark. I have the automatic brightness turned off btw.
    Has anyone else noticed this?
    Quote Originally Posted by ScottyPimpin View Post
    The proximity sensor uses light to determine distance from face etc. with little light then sudden light from the display, the sensor is just try recalculate distance (and sometimes it is wrong) and this is what you are noticing.
    If the problem occurs during normal to low lighting, then there maybe a problem.
    That makes sense, i kinda figured that. It doesn't give me any issues unless it's pitch black in the room.
automatic dark light sensor with loud speaker-
dark room light detector
dark room sensor
light detector dark room
proximity sensor in a dark room
sensor to tell a room is dark
