nexus 1 and factory sd card,not recognizing??
This is a discussion on nexus 1 and factory sd card,not recognizing?? within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; i just got my nexus one,came with the factor sd card in it,but i turn the phone on and it says there is no sd ...
Thread: nexus 1 and factory sd card,not recognizing??
    Member bmf5150's Avatar
    i just got my nexus one,came with the factor sd card in it,but i turn the phone on and it says there is no sd card?any ideas?thanks
    stan
    i will try that,do you normally have to do that?
    it fixed it,thank you for the help!!!
    At times my gallery shows nothing as well. Everything is saved on memory card as well. Can't be sure if it is the device or the card. My guess is it is the device most likely.
  1. Confused about WiFi Calling
    Last Post: 05-10-2013, 03:00 PM
  2. Buy a Second battery
    Last Post: 12-02-2010, 06:44 PM
