Voice dial problem... adding local settings numbers
This is a discussion on Voice dial problem... adding local settings numbers within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Ok, I've selected the UK local settings for my Nexus, but that is not my current location. Whenever I am trying to use the voice ...
Thread: Voice dial problem... adding local settings numbers
    Junior Member djpaan's Avatar
    Whenever I am trying to use the voice dialing option, the phone recognizes my choice, but it ADDS +44 in front of my number. Is there any way I can turn off this?
    Thanks in advance,
    A
    Quote Originally Posted by djpaan View Post
    Thanks in advance,
    A
    I believe the problem is your 'UK local settings'. The Nexus is assuming that all calls requested are UK type numbers and because the phone is not in the UK locale, it's putting the +44 country access code for you.
    I know that is the source of my problem, but is there a solution on how to turn off that local when using voice dial?
    A
    No!!
    Nexus design.
