Missed call - trackball not flashing
This is a discussion on Missed call - trackball not flashing within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Yeah, I have the aforementioned issues as well and would like to see a better solution than a light that blinks "once" in hopes that ...
Results 21 to 30 of 33
Thread: Missed call - trackball not flashing
  1. #21
    Member Evil Claw's Avatar
    Yeah, I have the aforementioned issues as well and would like to see a better solution than a light that blinks "once" in hopes that you see it when it does.
  2. #22
    mine blinks until i pull down notification bar
  3. #23
    Member vineetpatel_nexusone's Avatar
    Never really noticed this "issue", but the same for me on stock rom - pulse light blinks for SMS, but not for missed calls.
    Are we getting multi colored pulse notification on Froyo?? If so, this may fix it.
  4. #24
    Re: Missed call - trackball not flashing
    Get rooted get multi colored
    my other phone's a nexus too
  5. #25
    Junior Member vin888's Avatar
    Can anyone with the new firmware (2.2) confirm if the option for miss called pulse notification works?? is there multi color light?
  6. #26
    Junior Member SteveAu's Avatar
    using 2.2 but the sms led light i change to red..but there is no LED light at all..
  7. #27
    Senior Member FC1032's Avatar
    Quote Originally Posted by vin888 View Post
    The LED notification in 2.2 works (does flash continuously after a missed call if you lock the screen). I haven't found colour options though (tried downloading trackball alert, even though i know you need root and custom rom, not surprisingly it didn't work)
    Quote Originally Posted by SteveAu View Post
    Where did you select the LED colour?
  8. #28
    62 times
    Quote Originally Posted by FC1032 View Post
    Handsent has notification settings that include LED color...the alerts only occur when the phone is dim/asleep.
  9. #29
    hmmmm... Handcent isn't working that well in Froyo. It doesnt send my messages properly.
    I'm uninstalling it till an update for froyo comes out.
  10. #30
    62 times
    Yep..it's fc'ing, but still sending out sms's. Hope dev fixes it asap.
