DST issues
This is a discussion on DST issues within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Anyone having problems with the Nexus One (and MyTouch 3G) not properly changing the time after the switch to DST? I live in EST, and ...
Thread: DST issues
    Junior Member jj15951's Avatar
    Exclamation DST issues
    I live in EST, and when I check "automatic (use network provided values) in settings > date & time, instead of 'GMT-04:00, Eastern Daylight Time,' my phone uses GMT-05:00, Central Daylight Time. This screws up the date stamps in GChat and the calendar! Any ideas?
    Quote Originally Posted by jj15951 View Post
    It sounds like your network hasn't update their time stamp. (which I doubt).
    If you call your cell does it show the right time?
    With my previous SE w850 phone, even though I had it set for 'use network..'
    it didn't update until I received a call on the day change or sometime during that same day.
    I never figured out why, just got used to it.
    Everything shows the right time, just the date stamps are screwed up if I use the "automatic settings" -- the clock and call logs show the right time, but the calendar times and text message/email/gchat time stamps are incorrect. Weird right?
    Just to confirm it's not a software glitch, remove the battery for three mins.
    then replace and power on the Nexus again...
    I don't think a factory reset is needed (only a last resort).
    I think that worked! Thanks so much!!!!!!
