Any one having this reception problem with the At&t Nexus One??
This is a discussion on Any one having this reception problem with the At&t Nexus One?? within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; im in a great ATT 3g area...and i notice from time to time, i have no data for no reason...and the 3g is gone from ...
Thread: Any one having this reception problem with the At&t Nexus One??
    Junior Member one028's Avatar
    im in a great ATT 3g area...and i notice from time to time, i have no data for no reason...and the 3g is gone from the signal meter in the status bar. it comes back, but its really annoying, because i cant do anything with data for the few seconds i have no coverage, even though i have full bars of 3g coverage in my house...weird...
    when i try to access an app or go on the internet...i have full bars of 3g service and i get a "NETWORK ERROR" message...goes away, but very very annoying for the 5-10 seconds i cant access any type of data...
    it would make sense if i was in a bad signal area...but it doesnt even switch to Edge...i get nothing....i have checked all the settings and all is set correctly...
    i have never had any problem with any Att phone.....
    Android Lurker maris's Avatar
    Is it possible you need a particular data plan for the Nexus? When I got mine on T-Mobile I had to change to an Android data plan (no change in price) in order for it to work correctly.
    Junior Member Rino808's Avatar
    I just got my ATT N1 today and i do have the same reception issues...it jumps in and out of 3g, and edge. Its not the plan that is doing that, cause i am on the basic data plan for regular phones (Media Net) I dont have a smartphone or iphone plan...its the phone. i have a milestone and the reception on that phone is awesome...it also d/l's data on hspa (H)...i thought this nexus one would also let the phone have hspa speeds...any fix to this...im really getting irritated with these issues...
  1. e-mail updates
    Last Post: 09-01-2010, 01:41 PM
