Nexus One will not send MMS via WiFi or through network
This is a discussion on Nexus One will not send MMS via WiFi or through network within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I really hope someone can help as this has been doing my head in since I got the handset in January. Nexus One will not ...
Results 1 to 10 of 11
Thread: Nexus One will not send MMS via WiFi or through network
    Junior Member martinginnelly's Avatar
    Nexus One will not send MMS via WiFi or through the network -
    I have:
    Wiped and reinstalled the software
    Manually built the APN settings in handset
    Tried handset with different sim card on alt network (with correct settings)
    Tried on 3G network only then converted to 2G only
    I have the G1 handset as well and my sim works fine in that handset and sends the MMS ok. Compared the settings and all seem fine.
    Can someone help please
    Thanks
    Martin
    What are your exact APN / MMSC settings?
    Junior Member reapur's Avatar
    I have an N1 and I have the same problem. I just thought it was normal
    Another thing Android seems to need work on.... Sigh
    Hi Bishop09,
    The settings are:
    APN: general.t-mobile.uk
    Proxy: Not set
    Port: Not set
    Username: t-moible
    password: one2one
    mmsc: http://mmsc.t-mobile.co.uk:8002
    MMS proxy: 149.254.201.135
    MMS Port: 8080
    MCC: 234
    MNC: 30
    Aithenication: PAP
    APN type: Not set
    Also tried as told by HTC:
    Name:T-Mobile UK Picturemessage
    Proxy: Not set
    Port: Not set
    Username: t-moible
    password: one2one
    MMS Port: 8080
    MCC: 234
    MNC: 30
    Aithenication: CHAP
    APN type: mms
    Try these settings...
    All other settings not listed below, leave blank.
    Username: user
    PW: one2one
    MMSC: http://mmsc.t-mobile.co.uk
    MMS Proxy: 149.254.211.10
    MMS Port: 8002
    Username: user
    Pw: pass
    MMS Proxy 149.254.211.10
    MMS Port: 8080
    Username: user
    PW: one2one
    MMS Proxy: 149.254.1.10 or 149.254.201.132
    MMS Port: 8080
    Also for your particular settings, try the 'user / pass' or 'user / one2one' for username and password, and leave aithenication & APN type blank.
    Junior Member ctgilles's Avatar
    Quote Originally Posted by reapur View Post
    Got mine to work by setting Internet after MMS and setting Internet as default while mms stays mms
    Can you please walk me thru these step. I'm not able to find the settings i Need to make this change.
    Thanks,
    Quote Originally Posted by ctgilles View Post
    First I set up my MMS (operator specific) and the APN type mms
    Then I set up my Internet (operator specific) and the APN type default
    Now I am able to MMS but the pics are very compressed. I do think this is operator related as Proximus only allows 100KB
    Thanks. I guess I don't know where to make these changes. Can you point me to a thread or a faq. My n1 just worked when I turned it on and I can't find where in the menus to make these manual changes.
    :P
    Thanks
    :P
    Thanks
    Menu > settings > wireless & network > mobile networks > Access Point Names
android mms via network
nexus mms wifi
nexus one not sending picture messages
