Calls will not complete
This is a discussion on Calls will not complete within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi all! I am having trouble with my new (as in one day) Nexus One. I am able to send and receive texts, internet works ...
Thread: Calls will not complete
    Junior Member fuzzychaos's Avatar
    Hi all! I am having trouble with my new (as in one day) Nexus One. I am able to send and receive texts, internet works fine. I can receive calls, but when I make a call, it rings once, beeps and then drops. I tried removing the battery and sim card and also tried turning airplane mode off and on. Do I have a defective phone or it is the all too common call issues? Should I try to get a replacement?
    Also, are these issues happening with the various mods (i.e. Cyanogen)?
    Quote Originally Posted by fuzzychaos View Post
    Is your 'Fixed Dialing Numbers' enabled? (menu > settings > call settings > FDN.
    If it is then you have a restriction on outgoing calls made.
    If not, check with your carrier that the sim card is active for outgoing calls.
asus zenfone 4 outgoing call are restricted by fdn
calls restricted by fdn droid razr
disable fdn droid razr
droid razr outgoing calls restricted by fdn
fdn droid bionic
how to disable fdn on droid 4
how to disable fdn on droid bionic
how to disable fdn on droid razr
outgoing call restricted by fdn
outgoing call restricted by fdn zenphone 5
outgoing calls are restricted by fdn
outgoing calls are restricted by fdn droid 4
outgoing calls are restricted by fdn droid razr
outgoing calls are restricted by fdn motorola razr
