trackball randomly glowing
This is a discussion on trackball randomly glowing within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; For the past couple of days the trackball on my N1 has started glowing randomly, and also when i press the lock key. It seems ...
Thread: trackball randomly glowing
    Member greg_nexusone's Avatar
    For the past couple of days the trackball on my N1 has started glowing randomly, and also when i press the lock key. It seems to flash roughly every 1-2minutes. There's no notifications in the bar, and I've tried restarting it.
    It's getting annoying as I keep thinking I have a new message or alert :S
    anybody seen this and know of a fix?
    Junior Member dandv's Avatar
    Lightbulb It's the clock or calendar app
    I have the same problem as Greg - the trackball flashes randomly, without any real notification. (It doesn't flash rapidly, so the thread posted above doesn't apply).
    I've narrowed down the culprits to the Clock or Calendar application (or each). After I kill them, the trackball stays off. Now I need a good application to auto-kill these bastards, because TaskPanel doesn't do it right (they keep respawning and TaskPanel doesn't kill them). On the other hand, if you kill these apps all the time, you might not have alarms and whatnot.
    I'm using CyanogenMod 5.0.2.
    yeah, it's not blinking rapidly
    i did wonder if maybe battery lite was causing it.
    FWIW I'm running on stock firmware, it's not rooted.
