Need Help
This is a discussion on Need Help within the Nexus One Themes forums, part of the Nexus One category; Hello Friends i just brought my Nexus One don't understand following things. 1) How to Transfer Images & Music into phone from Windows PC ? ...
Thread: Need Help
    Junior Member sikandar's Avatar
    Need Help
    2) How to save Images while we are online from Nexus 1 from any website ?
    3) is there any Nexus one PC Suit Avalible ?
    Thanks in Advance.
    Junior Member manteka's Avatar
    1) Plug the phone into your computer, pull down the notification bar, and click "USB Connected". Then click "Mount," and your phone should appear on your computer as a normal external harddrive, where you can upload whatever you like.
    2) Press and hold the picture until a menu shows up then select to download the picture
    3) Suit???
    Cool
    Thank you very much bro u r da Hero :-)
