Is This Problem With The Nexus1 Or Tmobile?
This is a discussion on Is This Problem With The Nexus1 Or Tmobile? within the Nexus One forums, part of the Google Phones category; yeah it gives me the error message when i try sending the message n its really annoying cuz id have to close the phone and ...
Results 11 to 18 of 18
Thread: Is This Problem With The Nexus1 Or Tmobile?
    Senior Member astros148's Avatar
    yeah it gives me the error message when i try sending the message n its really annoying cuz id have to close the phone and reboot it and then it allows me sending the message
    so what do you think i should do?
    Junior Member Nick Found Gloryx's Avatar
    this happens to me all the time, when it does, i turn off 3g for a couple seconds, turn it back one and resend it.
    so this has to do with the andriod platform itself and not the messaging app?
    Member TechieNewsMongral's Avatar
    OK just a thought here, has anyone checked if their service center number is updated on the phone? I know some people may not know how to do it so here we go.
    You first want to pull up the dial pad and enter *#*#4636#*#*. This will pull up a menu of options on the phone. In the display screen, go to "phone information" and scroll to bottom where you see "SMSC" and the box to the right should be blank. You want to press refresh. At this point you should see "+12063130004" in the box. tap on update followed by the home button to return to the main screen and power cycle the phone.
    From here out, you should not have the issues again however things do happen unfortunately.
    hope this helps
    Regards,
    TechieNewsMongral
    tinyurl.com/techienewsmongral
    of course you want to test resending the sms when you power the phone back on.
    again... hope this helps
    Regards,
    TechieNewsMongral
    That's a great help Techi....I really like your site as well....Thanks very much!:nexusx:
    Thanks for the info. If it works, you may have saved quite a few headaches.
    Bought the AT&T N1.
    Junior Member AndroidRolando's Avatar
    Apr 2011
    didn't work with nexus s, koodo mobile
