T-Mobile Web2go 3g speed.
This is a discussion on T-Mobile Web2go 3g speed. within the Nexus One forums, part of the Google Phones category; I just realize I'm on their HSDPA network too, Isn't that faster than normal 3g? I really need to upgrade the data plan then....
Results 11 to 16 of 16
Thread: T-Mobile Web2go 3g speed.
    Member wormbaby's Avatar
    Junior Member philhyde's Avatar
    Question
    Quote Originally Posted by wormbaby View Post
    No, you don't need a new sim card. You just need to call up T-mobile, and tell them you want to add web2go to your plan. And tell them you have a non-smartphone. Then follow this instruction. Android Forums - View Single Post - Web2go on Nexus 1, SOLVED!
    Why would I need that? Data works just fine.
    Besides, I have a corporate account, and I cannot make changes.
    Member TechieNewsMongral's Avatar
    Quote Originally Posted by techieNewsMongral View Post
    Also ensure your APN is correct for 3G smart-phones which should be "epc.tmobile.com". This of course should be automatically set when you lace a sim card in the phone no matter the carrier.
    I thought I have to use internet2.voicestream.com for the web2go to work. So, 500 Kbps is about right for web2go 3g? I guess I'll have to fork out $25 for the android data plan. Or maybe I can live with it until they detect me.
    PS: yep, I need to use internet2.voicestream.com for web2go to work.
    T-Mobile is doing away with internet2.voicestream.com AND internet3.voicestream.com, also WAP.voicestream.com.. they are leaning eventually to epc.tmobile.com on smart phones... web2go isnt going to last long and eventually it will give an up sell.. BUT, I definitely understand wanting to wait so u can save money either way...
    Regards,
    TechieNewsMongral
    tinyurl.com/techienewsmongral
    Besides, I have a corporate account, and I cannot make changes.[/QUOTE]
    Sorry, I thought you don't have data yet. If it works, great. You should see the 3g icon on your bar on your n1 if you are getting 3g.
    Quote Originally Posted by jimbobalu View Post
    wormbaby,
    Where do you make the apn change? I am interested in getting the we2go plan also.
    Thanks
    Look at post #10 if you still interested in adding web2go.
    Yeah, I have a Blackberry plan.
    I do see 3G, but honestly, the signal seems to drop a lot. I don't think T-Mobile has a good 3G presence in my area.
  1. Battery Life + Info Re: Desktop Dock
    Last Post: 09-06-2010, 07:57 AM
httpol://p/m.web2go.com/
speed mobile 3g android
u web2go
u.web2go
u.web2go android
u.web2go.com / upsell / mbb.do
u.web2go.com/upsell/options.do?url=http://www.amazon.com/uverse-gateway-broadband-router-wireless/dp/b009594cfg&fteflag=
uweb2go
we2go
web 2 go .com upsell
web2go on nexus 1 solved android
web2go upsell options
web2go virus
what is web2go upsell
www.web2go.com
