T-Mobile Web2go 3g speed.
This is a discussion on T-Mobile Web2go 3g speed. within the Nexus One forums, part of the Google Phones category; I just got my Nexus One yesterday. I'm a little discouraged by the speed in 3g. I have the $9.99 web2go, and yes, I made ...
Results 1 to 10 of 16
Thread: T-Mobile Web2go 3g speed.
    Member wormbaby's Avatar
    I just got my Nexus One yesterday. I'm a little discouraged by the speed in 3g. I have the $9.99 web2go, and yes, I made the changes in apn for it to be in 3g. I have 3 - 4 bars of 3g. I'm only getting 500 Kbps (.5 Mb/s). Is this normal? Thanks for the help.
    PS: I love the phone.
    Member jimbobalu's Avatar
    wormbaby,
    Where do you make the apn change? I am interested in getting the we2go plan also.
    Thanks
    Member TechieNewsMongral's Avatar
    Quote Originally Posted by wormbaby View Post
    the $10.00 plan is the reason why its not up to par. you will need the proper data plan on the account for it to work. otherwise eventually you will receive the "upsell" message and be forced to get the proper data plan and android feature on account
    Regards,
    TechieNewsMongral
    tinyurl.com/techienewsmongral
    Junior Member philhyde's Avatar
    I just switched from a Blackberry Curve 8900 to the N1.
    Question - do I need to visit a T-Mobile store and get a "3G" SIM card?
    Quote Originally Posted by philhyde View Post
    no the sim card isn't what makes you able to have 3g, its the phone capabilities to detect it
    Regards,
    TechieNewsMongral
    Wink
    Quote Originally Posted by techieNewsMongral View Post
    Thanks, I wasn't sure if there was something different about the SIM cards that are labeled 3G.
    Your lucky I get 200-300 kbps on hsdpa
    Froyo 2.2 Stock
    RA-nexus-v1.7.0
    [SIGPIC][/SIGPIC]
    Also ensure your APN is correct for 3G smart-phones which should be "epc.tmobile.com". This of course should be automatically set when you lace a sim card in the phone no matter the carrier.
    Regards,
    TechieNewsMongral
    I thought I have to use internet2.voicestream.com for the web2go to work. So, 500 Kbps is about right for web2go 3g? I guess I'll have to fork out $25 for the android data plan. Or maybe I can live with it until they detect me.
    PS: yep, I need to use internet2.voicestream.com for web2go to work.
    No, you don't need a new sim card. You just need to call up T-mobile, and tell them you want to add web2go to your plan. And tell them you have a non-smartphone. Then follow this instruction. http://androidcommunity.com/forums/285644-post1.html
  1. Battery Life + Info Re: Desktop Dock
    Last Post: 09-06-2010, 08:57 AM
httpol://p/m.web2go.com/
speed mobile 3g android
u web2go
u.web2go
u.web2go android
u.web2go.com / upsell / mbb.do
u.web2go.com/upsell
u.web2go.com/upsell/options.do?url=http://www.amazon.com/uverse-gateway-broadband-router-wireless/dp/b009594cfg&fteflag=
uweb2go
we2go
web2go on nexus 1 solved android
web2go upsell options
web2go virus
what is web2go upsell
www.web2go.com
