Change Default Search Engine on Nexus
This is a discussion on Change Default Search Engine on Nexus within the Nexus One forums, part of the Google Phones category; Does anyone know if it is possible to change the Search Engine from Google to something else on the Nexus One? I bought this phone ...
Thread: Change Default Search Engine on Nexus
    Senior Member thomaslkuo's Avatar
    Does anyone know if it is possible to change the Search Engine from Google to something else on the Nexus One? I bought this phone so I can use both in China and U.S., but with Google backing away from China, how will I be able to use this phone? Just curious.
    Nexus One - CyanogenMod-5.0.6-N1
    Amon_RA Recovery v1.7.0
    2.6.33.2-cyanogenmod
    kmobs@ubuntu #3
    BUILD: EPE54B
    Baseband: 32.26.00.24U_4.04.00.03_2
    Swype BETA : NexTHEME Morph
    Juice Defender
    Follow me on Twitter
    Can't you just install another browser and use that instead?
    NO, as I understand the point of this phone is it's accessibility to the search engine with it's search key. You are only a softkey hit away from the net. And hitting that key accesses the Google Search Engine. But without a Google site in China, will it effect the full enjoyment of the phone. I think that when you hit Google.com in China, it will still access Google.com/hk the Hong Kong site. At least I hope. But I hear that Android phones in China are now being outfitted with Bing or other search engine. I wonder if that's something that I can do also.
    kmobs@ubuntu #3
    BUILD: EPE54B
    Juice Defender
    Senior Member ardynine's Avatar
    I don't think you can for now, but you can't possibly be the only one in this situation so I'm sure there will be some sort of "fix" from Google. Or at least I'm hoping so
    Thinking about it, I don't think it something Google will be wanting to fix, as it's a Google phone, using the Google search engine.
    So no... I don't think there will be much options for you.
    See what develops over time!!
    If their motto is "do no evil" or whatever it is, they should be giving you options. but of course, who am i to say
    Android Lurker maris's Avatar
    Why not just use the browser, enter "bing.com" and search away?
android change google bar to bing
can i change the default search angine on the nexus 6
change android search
change nexus 5 search engine
change nexus search 5 engine
cyanogenmod with bing
how can i change the default search in and nexus phone
how to add search engine to nexus 5
how to change android chrome search engine
how to change google search engine on nexus
how to change search engine nexus 5
how to change search engine to bing in nexus
nexuz 7 search bar search with bing
replace google search bar with bing nexus 7
using bing on a nexus phone
