seidio 3200 mah [replacement] battery (first day results...)
This is a discussion on seidio 3200 mah [replacement] battery (first day results...) within the Nexus One forums, part of the Google Phones category; Well its 10pm.... Today I disconnected my charger from my phone at 7:30am after charging it all night.... I made a 5min. phone call and ...
Results 1 to 10 of 16
Thread: seidio 3200 mah [replacement] battery (first day results...)
    Member 3xL's Avatar
    Exclamation seidio 3200 mah [replacement] battery (first day results...)
    Well its 10pm....
    I made a 5min. phone call and it went own from 100 to 96 percent. I was moving today to a different apt. So I spent most of my day NOT using it.
    Right now its 10:09pm (15hrs later) and that battery level is at 15 percent. I think This is OK. It should be atleast around 40-60percent (judging and estimating from other user carrying the same 3200mah battery).
    I can only assume and hope that this is bcuz its only been through one charge cycle. I will give u guys tomorrows results around the same tme.
    If I have another faulty battery, I am gonna be soooooo pissed....
    Member Solipsist8's Avatar
    Allow it to discharge enough to shut the phone down, before recharging it. This will calibrate the phones' meter accordingly.
    Member 3xL's Avatar
    A junior member telling me to remove me to remove my foul language? Ummmmm....yea were all adults here sooooo.... anywayss.....
    Yes I did all that. I'm at 8 percent now.... once it dies I will recharge all night
    Member Alexpeegs's Avatar
    Did you notice any improvments over the standard battery and also does it take a lot longer to charge?
    VZW Nexus One PLZ
    Member 3xL's Avatar
    Yes good improvement but not enough. Maybe in a couple of days?
    Senior Member disbj4ke's Avatar
    I have the Seidio 1600 and I notice a small difference from the stock battery just from that. You SHOULD have a very noticeable difference from the stock one. Give it a couple cycles and if it isn't getting better I'd talk to Seidio. What's your views on the casing for the larger battery?
    CyanogenMod 6.0.0
    Part Monster, Part Machine, ALL ANDROID
    Member 3xL's Avatar
    I love the larger case. More comfortable for my big sexy hands lol and less typos. Just feels right. I unplugged my phone from charger ten minutes ago and it went down 5percent with idleness. Not liking it one bit.... sigh
    @3xl Hope the second one works better for you. I haven't had any issues with my 3200 battery. I'm up to a full 2+ days with light use and 20+ hours with heavy use.
    Member 3xL's Avatar
    Hey mighty dude.... quit bragging, punk....
    Nah just kidding lol. I'm 3hours in and battery dropped to 83percet with light use.. I hope seidio sends me another replacement if I need it...
    @3xl Seidio appears to stand by their product when there's issues. I did find the level dropped quickly at first but that has diminished now. I now keep the phone on at night while charging and seems to have no effects on the charge. I haven't used the USB charging only the phone charger.
