requested ANOTHER seidio replacement / battery widget responsible?
This is a discussion on requested ANOTHER seidio replacement / battery widget responsible? within the Nexus One forums, part of the Google Phones category; So I requested ANOTHER replacement battery from seidio because the first replacement is faulty as well. But then I started thinking.... Is it possible that ...
Thread: requested ANOTHER seidio replacement / battery widget responsible?
    Member 3xL's Avatar
    Is it possible that a battery widget can cause battery corruption? I have one of those Widgets that tells u ur batttery life. I could be wrong. And I hope I am. Maybe I just have rotten luck lol
    Senior Member Budske's Avatar
    maybe u should try and uninstal every batery widget and only use the stock one
