Nexus one is not charging when I insert the usb / wall charger
This is a discussion on Nexus one is not charging when I insert the usb / wall charger within the Nexus One forums, part of the Google Phones category; Hello... Does anyone else out there have the same problem as me? Well, whenever I insert the usb / wall charger, my n1 often would ...
Results 1 to 10 of 14
Thread: Nexus one is not charging when I insert the usb / wall charger
    Senior Member Roxy's Avatar
    Hello...
    Well, whenever I insert the usb / wall charger, my n1 often would not charge.
    However, when I took out the battery and put it back in, sometimes it will start charging again. ( not all the time though... )
    What is wrong with my N1?
    PS - On the ' slide to unlock ' screen, it says that my phone is charging, but when you look at the battery logo, it isn't.
    The battery percentage just keeps going down.
    [ Cyanogen 5.0.5.6 | OC'ed to 1.113GHz | Amon RA v1.70 | Build EPE54B| Desire Camera R2 | NexTHEME 2.0 Final & Goodies5 R2 ]
    Sounds like you have a defective 'USB port' / charging Circuit, on your Nexus.
    You may have no choice but to give HTC a call...
    HTC ? Support ? Customer Service ? Support via Hotline
    Yeah, check the pins on the inside of the USB port. On one of my old BB's that had the micro USB charger, one of the pins got bent. It thought it was charging, but it wasnt since there was a pin contact missing.
    Bought the AT&T N1.
    Senior Member Budske's Avatar
    there was one guy with the same problem... to fix it he change the battery with a friend and change it back and it got fixed
    Hmm, people on xda forum told me that it's because of the fact that I OC/SetCPU/Kernel.
    r u sure????
    how do u fix it then???
    Quote Originally Posted by Budske View Post
    r u sure????
    Um they said I will be able to charge again when the battery goes < 90%, which is true for my phone.
    Quote Originally Posted by Roxy View Post
    r u sure????
    Interesting. Any idea why that combination of changes causes this?
    Bought the AT&T N1.
    r u sure????
    thats weird.... well, its good to know that
    Quote Originally Posted by jaeisber View Post
    r u sure????
    I'm not sure, but feel free to check my thread on xda forum periodically to see if anyone explain the cause of it.
    http://forum.xda-developers.com/show...45#post6104245
  1. How to silence ringers when on a call
    Last Post: 12-27-2010, 11:46 AM
android charger pins missing
google nexus one charging problem
google nexus one not charging
google nexus usb charge not working
how to fix charging issue on nexus one
htc google nexus one charging problem
htc nexus one battery removal charging
htc nexus one not charging
nexus 1 not charging
nexus one battery not charging
nexus one charging problems
nexus one does not charge battery
nexus one not charging battery
nexus one stopped charging
