can a battery reading widget corrupt a battery?
This is a discussion on can a battery reading widget corrupt a battery? within the Nexus One forums, part of the Google Phones category; Just wondering if that's possible cause I'm on my third seidio replacement. ......
Thread: can a battery reading widget corrupt a battery?
    Member 3xL's Avatar
    Quote Originally Posted by 3xL View Post
    It depends how it's polling data from the battery, so yes; it is possible.
    Your best bet would be to disable the app and monitor it from there!!
    Do you really think that it can "corrupt" a battery?
    Drain it maybe....
    OP, what do you really mean by "corrupt a battery"?
    Senior Member rioja's Avatar
    What is the app you're using???
    IMO, it's more likely you got 3 bad batteries from Seido.
