3g problem anyone?
This is a discussion on 3g problem anyone? within the Nexus One forums, part of the Google Phones category; Anybody other than me that have this problem,I can be on the phone with somebody and have no 3g in a known good area but ...
Thread: 3g problem anyone?
    Senior Member Macklessdaddy's Avatar
    3g problem anyone?
    Anybody other than me that have this problem,I can be on the phone with somebody and have no 3g in a known good area but I can hang up the call get the 3g back and call the person back and keep the 3g signal then.Basically is this an instance of the infamous 3g problem.
    To manually set 3g:
    Go to phone > dial *#*#4636#*#* then go to Phone Info and choose WCMA Only.
    This will keep you on 3G and force a better speed. If by chance you roam out of 3G coverage & find you need EDGE, you can easily switch back to WCMA Preferred.
*#*#4636#*#*3g not working
