Noise from car charging
This is a discussion on Noise from car charging within the Nexus One forums, part of the Google Phones category; Anyone else experiencing some interference noise when playing music while charging in the car? It gets worse when I step on the gas. Still there ...
Thread: Noise from car charging
    Junior Member nexash's Avatar
    Lightbulb Noise from car charging
    Anyone else experiencing some interference noise when playing music while charging in the car? It gets worse when I step on the gas. Still there when I coast though.
    I do. It's engine noise and there's nothing you can do about it. I've yet to find a gadget that doesn't do this while charging.
    If you have to charge while listening to music, turn the volume all the way up on the phone. It won't get rid of it, but it minimizes it.
    Senior Member number 9's Avatar
    It's ground loop interference, it's a common problem with charging circuits and audio equipment.
    ground loop isolator 3.5mm - Google Product Search
    There are some pretty cheap ground loop isolators out there. Hope that helps.
    Hmmm I've never heard any noise while listening/charging but then I drive a Corvette :rofl3:
android phone making noises while playing music in the car
static noise when charging cel in car
