GPS is not working properly ...Plzzz Help
This is a discussion on GPS is not working properly ...Plzzz Help within the Nexus One forums, part of the Google Phones category; I am working in Kuwait, and I have my N1 since a month. Since I get it and the GPS is not working. I switched ...
Thread: GPS is not working properly ...Plzzz Help
    Junior Member Mina_nexusone's Avatar
    Exclamation GPS is not working properly ...Plzzz Help
    I am working in Kuwait, and I have my N1 since a month. Since I get it and the GPS is not working. I switched ON the GPS from Settings. It can identify my location and it doesn't give any directions to anywhere !!! I tried on Google map, navigation2go and same result i get.
    Please Help !!
    Every time I try to get any direction is tellin me : " NO ROUTE AVAILABLE "
    Android Lurker androidvibe's Avatar
    Apr 2011
    Have you checked to see if the maps you have includes Kuwait addresses. There might be a download you need to get detailed maps in Kuwait. I just zoomed into Kuwait on my Nexus One and there were no specific addresses for any of the locations. It seems to me that you will need to get some type of detailed map download for that area. On the Garmin GPS devices I had in the past, certain areas needed different maps to get detailed information, this must be the case with Google Maps.
    4 times
    Anything else running that is using GPS?
    mah
    mah is offline
    Senior Member mah's Avatar
    Try downloading and running "GPS Test" from the market -- that app doesn't need maps and will let you figure out if it's a GPS hardware problem (assuming you know your approximate location by coordinates), or a map/navigation problem.
  1. When will the Behold get Android 2.2?
gps not working on nexus s
