Is this a problem?
This is a discussion on Is this a problem? within the Nexus One forums, part of the Google Phones category; On the bottom of the phone, in addition to the usb port, there are 4 dots, 2 on each side. 3 of them are filled ...
Thread: Is this a problem?
    Member The Law's Avatar
    Is this a problem?
    On the bottom of the phone, in addition to the usb port, there are 4 dots, 2 on each side. 3 of them are filled with a gold piece of metal, and the one on the far right is just a hole. Is that proper? I'm guessing maybe its the mic?
    Senior Member elvis1's Avatar
    This is normal.
    Junior Member blacknexus1's Avatar
    Re: Is this a problem?
    I was thinking the same thing at first
    Get a desktop dock and you'll find out what those are for!
    Junior Member Midwest Division's Avatar
    The 3 "filled" holes are for docking purposes and you're right...the "empty" hole is where the speaking mic is located.
