Is It Possible to Simultaneously Connect Two Bluetooth Headphones?
This is a discussion on Is It Possible to Simultaneously Connect Two Bluetooth Headphones? within the Nexus One forums, part of the Google Phones category; And secondly please let me know that how would the transmitter search the bluetooth earphones..? Will earphones search the transmitter or the transmitter will auto ...
Results 21 to 30 of 42
Like Tree1Likes
Thread: Is It Possible to Simultaneously Connect Two Bluetooth Headphones?
  1. #21
    Junior Member usmanulamin's Avatar
    Jul 2012
    And secondly please let me know that how would the transmitter search the bluetooth earphones..? Will earphones search the transmitter or the transmitter will auto search the earphones..?
  2. #22
    Junior Member btcolink's Avatar
    Apr 2012
    Cool
    Cannot see why not. But the only way is to pay and play! I use mine camping so the tv doesn't disturb nearby campers. They work very well.
  3. #23
    Apr 2012
    Wink
    AND to your "secondly"... I turn the tx on and then turn each headphone on separately until it connects...
  4. #24
    Jul 2012
    ok mate thanks for the info,ill buy the transmitter and earphones and will update that how do they work
  5. #25
    Junior Member acco's Avatar
    Aug 2012
    Office use of bluetooth
    Hi All,
    My scenario is similar as I need to have a number of reps in the one room who need to be able to answer a single mobile phone with their own headset.
    I understand the one at a time scenario with Bluetooth but is there a mobile phone that can handle having numerous headsets paired ready to answer when it rings?
  6. #26
    Junior Member rwjrn's Avatar
    Sep 2012
    Expensive Solution
    SMS Audio makes bluetooth headphones that are able to pair up to 4 to the same source. They are $399 per headphone on the SMS site, but Costco has them at 2 for $499
  7. #27
    Sep 2012
    Less Expensive solutions
    I have a Samsung HS 3000 bluetooth headset adapter. I plugged in a iLuv headphone splitter into the HS3000 and I have two pairs of headphones producing stereo sound each with it's own volume control. This works great on a plane as you don't have to have a cord connected to the iPad, just place the bluetooth adapter somewhere between the two people listening. This seems to work with plain headphones, and those with their own volume and phone controls. It does require corded headphones from the HS3000. There is also this option which I haven't tried: KOKKIA i10 MULTI-STREAM Tiny Bluetooth iPod transmitter splitter.
  8. #28
    Junior Member stugood's Avatar
    Sep 2012
    2 bluetooth headset receivers from one source (phone)
    Hello everyone,... well i was brought to this forum with a google search because i too am having the same problem and im glad ive come across this discussion and would be gratefull to anyone who can shed any light on this who has purchased any products that solves this problem.
    Now my problem is that iam a long distance runner/jogger and use my sony erricson x10 with the app cardiotrainer which monitors my speed, distance via gps ect.
    Now i already have a wireless bluetooth sony headset which works ok but now what i need is to connect another at the same time so my partner who runs with me can share my music tracks and also the vital information that is being broadcasted from the app on my phone,.... also if any products do work are there any headsets that would be water/splash proof?
    Would be gratefull for any info and would help us out quite alot.
  9. #29
    Tek
    Tek is offline
    Junior Member Tek's Avatar
    Jan 2013
    Bluetooth Splitter/Dual stream stereo audio A2DP
    Two hardware solutions are:
    BTSplitter35 Stream Bluetooth Audio Transmitter. It will stream the same audio source to both headsets simultaneously.
    Sena SM10 - the dual streaming feature of SM10, both you and your passenger may listen to the same music or radio at the same time by using Bluetooth headsets in the market
    I have two stereo speakers and have bought two mains powered stereo amps (Muse from AliExpress) for them - one for each speaker. I have then bought a stereo A2DP bluetooth receiver (BTR006 type/based) for each speaker from ebay. This makes each speaker 'wireless' - each speaker only needs to be plugged into mains power. The right speaker is connected to the right channel from the right BTR006 and vice versa for the left speaker. I then pair the two BTR006's to the dual stream transmitting device.
    I then would like to ideally transmit BT A2DP stereo from either my Laptop running a DJ program like NI Traktor or my Galaxy Nexus Android phone.
    Unfortunately neither of the latter will do dual stream bluetooth A2DP audio streaming???
    This can be sorted by using either of the above BT hardware TX solutions.
    Hope this helps - and hope the OS vendors will build this functionality in soon!
    Cheers
    Tek
    PS commecial speakers like what I am implementing are:
    Alto TS112w
    ACTIVE 800 WATT 2-WAY 12'' LOUDSPEAKER WITH WIRELESS CONNECTIVITY
    Built-in Bluetooth® A2DP wireless technology*
    Stream audio wirelessly from iPad, iPhone, iPod touch, Android devices and more
    Stream stereo signal, left and right, to separate speakers—no cables required
  10. #30
    Android Lurker bishwo370's Avatar
    Apr 2013
    Lightbulb
    Hi, I am bishwo, I have successfully connected 2 stereo bluetooth headset at once by using software Bluesoleil.
    just installed the software and paired 2 bluetooh headset and connected. no any problems now. before I am also thinking that it won't happen. after large number of trials I have done it. I have also tried 2 bluetooth dongle at once thinking it would help. but single bluetooth dongle is enough to connect 2 headset at once and both sounding ok.
    Contact me by PM.
    Last edited by UltraDroid; 04-10-2013 at 12:56 AM. Reason: Removed personal email address from post
  1. Replies: 0
    Last Post: 01-20-2011, 09:51 AM
  2. What Bluetooth Sports Headphones?
    By Hawkins_Family in forum Nexus One Accessories
    Last Post: 12-26-2010, 03:44 PM
  3. Can't connect by Bluetooth
    By rek16 in forum Sprint
    Last Post: 06-12-2010, 07:28 PM
  4. Looking for good Bluetooth headphones
    By N_1 in forum Nexus One Accessories
    Last Post: 02-24-2010, 02:43 PM
  5. Bluetooth Headphones.
    By cj2185 in forum Nexus One Accessories
    Last Post: 01-23-2010, 11:45 AM
*@s4computer.at
android watches able to connect to 2 bluetooth devices at once
can i use bluetooth to connect 2 earphones
can you connect two sets of bluetooth earphones with one android device
connecting two bluetooth headsets to the same surface so two people can listen to music
dual bluetooth app
dual bluetooth connection
how to connect two bluetooth headphones simultaneously
how to connect two wifi in android mobile simultaneously
how to connect zonoki wireless headphones to xiaomi phone
two bluetooth headphones at once
two bluetooth headphones at once android
two headphones one bluetooth
two pairs of bluetooth headphones to one handset
wireless headphones for android
