N1 data connection issue... please help!
This is a discussion on N1 data connection issue... please help! within the Nexus One forums, part of the Google Phones category; Hi everyone, I had a quick question I needed your assistance on. Sometime I put my N1 into Airplane mode to save battery and when ...
Thread: N1 data connection issue... please help!
    Senior Member ap3604's Avatar
    Unhappy N1 data connection issue... please help!
    Sometime I put my N1 into Airplane mode to save battery and when I finally turn airplane mode off I can never seem to get a data connection unless I totally shut off the phone and turn it back on again. Coming out of Airplane mode there will be a 3g signal on the status bar but only the up arrow will light up and anything needing data (browser, market, etc) wont work unless I totally shut off the phone and turn it back on again. Is this happening to you too?
    The same thing happens if I open up the Quick Settings app and turn off mobile data (to save battery) and when I turn mobile data back on I have to restart the phone entirely for it to work properly.
    It seems like my phone might be having an issue with data connection so I might have to call up HTC about it but I wanted to find out from the other members on the forum if this was happening to them too.
    Thank you for your help
    Try going to settings>Wireless Networks>Mobile networks. Then turn the 2g on, let it setup, go back and turn the 3g back on.
    I was able to get mine to work doing that when it happened to me. It only happened once though.
    62 times
    Toggling 2G-3G as above, or I've had success just searching for networks, manually selecting TMO (or your provider).
