Phone got VERY hot with car charger & GPS
This is a discussion on Phone got VERY hot with car charger & GPS within the Nexus One forums, part of the Google Phones category; Originally Posted by wacko I've hit 120F before... LoL your a MAN'S man!!! Surprised your phone battery doesn't explode...
Results 11 to 15 of 15
Thread: Phone got VERY hot with car charger & GPS
    Senior Member ap3604's Avatar
    Quote Originally Posted by wacko View Post
    62 times
    Grab a multimeter and test the unloaded output of that charger. If it's more than 7 volts, I wouldn't use it any more. Shop for a charger that advertises 'switch-mode' or 'regulated'..it's more likely to be about 5-6 volts unloaded, and the proper 5 volts when loaded.
    Junior Member wacko_nexusone's Avatar
    Quote Originally Posted by ap3604 View Post
    to put it in context, the ambient temperature is typically about 90F, and my car's air conditioning was a bit spotty..
    Yeah I've had a high temp (I think like 104*) once before too when I had the wifi on by accident, screen at 100%, and google navigation going.
    Just make sure that the charger isn't measuring over 7 volts unloaded, it will have no where to shunt the excess power besides the battery and circuitry which causes heat that might harm the phone.
    Oh, forgot to mention that the phone got so hot, the touch screen became totally unresponsive. All was well after some cooling down.
car charger heat my mobile
car charger heats ohone with gps
car charger makes phone hot
carcharger hot
cell ph getting hot on car charger and stops charging
cell phone car charger heating up
cell phone gets hot when charging in car
extremley warm chargin phone
my car charger makes my phone hot
phone charger gets hot in car
phone got hot while on car charger
phone heating up when charging in car
phone is warm car charger
phone with gps and car charger
why does my phone get hot on the car charger?
