Phone got VERY hot with car charger & GPS
This is a discussion on Phone got VERY hot with car charger & GPS within the Nexus One forums, part of the Google Phones category; I used my Nexus to find my doctors today, using the built in "Car Home" software, and it worked great. I had it plugged in ...
Results 1 to 10 of 15
Thread: Phone got VERY hot with car charger & GPS
    I used my Nexus to find my doctors today, using the built in "Car Home" software, and it worked great. I had it plugged in to a USB car charger by Griffin, and the device staid it was charging while navigating, but the phone got very hot to the touch... is that normal?
    AT&T Nexus One - Not Rooted
    Wave Secure + Lookout
    Quote Originally Posted by VydorScope View Post
    is that normal?
    Normal? My phone also gets very warm while charging and having the GPS turned on. It means the phone is using a lot of power which is somewhat expected when it is running the cell radio, getting data, using the GPS receiver, and charging the battery.
    It also mirrors my experience of running Google Maps on my phone. The battery will drain in just a couple of hours or so due to all of the activity. A lot faster than with the phone sitting fairly idle.
    :nexusx:
    AT&T ne:nexusx:us S on AT&T
    Archos 70 with UrukDroid
    I make sure that Wifi is off in the car dock. Also, don't set the screen to full brightness (though I'd love to sometimes). Otherwise, the charger can't even keep up while GPS and maps is active.
    With wifi off can your car charger keep up?
    Also, when using the Nexus One in your car, try to keep it out of the direct sun light - that adds to the heat factor too.
    I think so, as long as the screen is not at full brightness.
    I'll be keeping an eye on this. I've only had it about a month.
    Mine definitely did not keep up, I had less power at end of drive, I will have to try adjusting brightness down, and turning off wifi and see how it goes.
    Senior Member ap3604's Avatar
    Smile
    Yeah its normal but get the battery indicator app for your N1. It lets you know the battery temp if it gets too hot. Personally I don't let min get above 100* F.
    Quote Originally Posted by ap3604 View Post
    Which one do you use? I grabbed BatteryTime Lite which does not do what I hoped (put a % indicator in the notification area).
    Junior Member wacko_nexusone's Avatar
    I've hit 120F before...
car charger heat my mobile
car charger heats ohone with gps
car charger makes phone hot
carcharger hot
cell ph getting hot on car charger and stops charging
cell phone car charger heating up
cell phone gets hot when charging in car
extremley warm chargin phone
my car charger makes my phone hot
phone charger gets hot in car
phone got hot while on car charger
phone heating up when charging in car
phone is warm car charger
phone with gps and car charger
why does my phone get hot on the car charger?
