mms problem
This is a discussion on mms problem within the Nexus One forums, part of the Google Phones category; anyone else having problem sending and receiving mms? ......
Thread: mms problem
    Member missnexus's Avatar
    mms problem
    I was having a problem receiving mms pictures yesterday. I fixed it by sending a picture from my phone to my phone and that did the trick - no more problem.
    Member Mitch_nexusone's Avatar
    yeah dude i cant send or recieve either..
    I dont know what to do.
    Senior Member f0ul99's Avatar
    Re: mms problem
    I have got the same problem with mms. Seem that somehow, I can recieve it but couldn't download the image.
    A few days ago I play around with the APN setting and it works. But now got a new problem, I have to swap APN. If normal usage I'll use the Data setting(3G) and if got MMS I'll use the MMS setting. If I use the MMS setting then the Data will not available. So suck... but it's the carrier problem not the N1.
    Senior Member rioja's Avatar
    Quote Originally Posted by f0ul99 View Post
    You can create 2 APN's on your phone. One for normal data and the other for MMS.
    Just go into Access Point Names where your APN is and, press the Menu softkey and add a new APN for MMS. They should both work without swapping anything
amazon fire phone failed to download mms
amazon fire phone mms download failed
android mms problem
android mms problems
fire phone mms troubleshooting
kindle fire.phone mms failed download
mms download failed amazon fire phone
mms download failed on fire phone
mms fire phone
mms message failed fire phone
problem with mms in kindle fire phone
