My fix for accidentally hitting the home button when using the trackball.
This is a discussion on My fix for accidentally hitting the home button when using the trackball. within the Nexus One forums, part of the Google Phones category; I got fed up enough to do something about it. I have pics of the process if anyone is interested. It's basically some quality time ...
Results 1 to 10 of 12
Thread: My fix for accidentally hitting the home button when using the trackball.
    Junior Member mattanonymous's Avatar
    I got fed up enough to do something about it. I have pics of the process if anyone is interested. It's basically some quality time with painter's tape, epoxy putty, a $5 ebay case, and a dremel.
    Also, does anyone else wish the trackball had a bit more resistance? It feels loose and sometimes reacts opposite in direction to my input.
    Matt
    Member xkillerbx's Avatar
    Your fix was to totally remove it? Did you cut the bottom piece of the phone away and then epoxy it back? I'm not sure what to say.
    Member svenner's Avatar
    ummmmm........
    Member mush03's Avatar
    looks so ghetto >_>
    Member NexusRocks's Avatar
    Looks like somebody forgot to take their meds today
    Member adztaylor's Avatar
    Congrats for making a great phone look crap.
    Metro Atlanta
    54 times
    Looks like he built a "berm" out of epoxy between the trackball and the home keys. Am I wrong?
    Member Abrupt Demise's Avatar
    That's what it looks like to me.
    On trackball related note, is there a way to make it more sensitive? I find it's too unresponsive for my liking.
    Someone should take your Nexus One away from you!
    Come here little sheep; I have a nice juicy apple for you!
    [SIGPIC][/SIGPIC]
    Nexus One: Locked and Rooted
    ROM: CM7
    Absolutely right. And it's attached to a $5 ebay case, so no harm done to the phone.
    Yeah, it does look crappy at the moment. I'm sure that can be fixed with some spray paint, but I don't feel like running out to get it.
    Love the comments, though. I forgot what serious business the Internet is.
has google fixed accidentally hitting home button
i'm alway accidentally hitting the back key on the galaxy s3
