3g Speed drop
This is a discussion on 3g Speed drop within the Nexus One forums, part of the Google Phones category; Here is an odd issue, I am in NYC and get great connection speeds, often over 3000kbs. Then out of no where it drops to ...
Thread: 3g Speed drop
    Junior Member mike3000's Avatar
    3g Speed drop
    Here is an odd issue, I am in NYC and get great connection speeds, often over 3000kbs. Then out of no where it drops to 600k, while my other phone, a mytouch still gets over 3000 right next to the N1. If i turn on airplane mode and then off, i start getting over 3000 again. Any ideas anyone?
    Junior Member chrisofknives's Avatar
    I'm in Pittsburgh and mine went from roughly 3200kbps to 150. Mine isn't even fluctuating though. Mobile data didn't work at all yesterday. Today I'm just getting edge. I don't get it.
    im getting a similar issue...i get good speeds up to 4mbps then an hour later ill try it and get lousy speeds like 400kbps, then i restart the phone and im back up at 3-4mbps....any ideas why that is?
    Junior Member Waynelu90's Avatar
    HSPA+ speeds rolling out
    62 times
    Quote Originally Posted by Waynelu90 View Post
    That's what I'm thinking..I've heard it takes up to a few weeks to get all the towers up and stable in any particular area, and naturally, first-tier tech support is out of the loop on this stuff.
