Problems with antenna?
This is a discussion on Problems with antenna? within the Nexus One forums, part of the Google Phones category; I have T-Mobile on my Nexus One and for some reason the network drops every now and then. For instance I'll be texting and then ...
Thread: Problems with antenna?
    Member Zach's Avatar
    I have T-Mobile on my Nexus One and for some reason the network drops every now and then. For instance I'll be texting and then when I try to send the text it says it can't. So then I search for a network and I says that there is an error so I just restart my phone. Is anyone else on T-Mobile having that problem or is it a problem with the phone?
    Senior Member Syntax323's Avatar
    I had the same problem when I had v2.1
    I flashed mine to v2.2(FroYo) and I have yet to run into that issue, or the sending a text issue. So, it looks like they fixed something in the software that was bugging out. Just wait a little bit longer and everything will be fine, guaranteed!
    Also, off-topic, but what part of Seattle you from? City or a outskirt town?
    City 10 minutes away from downtown
    Thanks
    Lived in Federal Way for 19 years.
    No Problem, FroYo should be coming REAL soon.
    Ah yeah Federal Way is nice I used to swim at the aquatic center down there.
  1. T-Mobile announces Dell Streak 7, it's first 4G Tablet
    By JohnDroid in forum Android News
    Last Post: 01-06-2011, 02:22 PM
antenna in android phone problems
antenna problem on android
nexus 4 antenna problems
