Data usage and speed tests
This is a discussion on Data usage and speed tests within the Nexus One forums, part of the Google Phones category; I just wanted to remind everyone that speed tests use a LOT of data. For example: a single speed test that hits a download speed ...
Thread: Data usage and speed tests
    For example: a single speed test that hits a download speed of 2Mbps uses about 25MB of data just for the download. So if you also get 1Mbps up, that's another 12.5MB of data. So for ONE speed test you've used 37.5MB of data. If your speeds are faster, you're also using more data.
    So "testing" your 3G speeds will burn up your data plans like nobodies business.
    That was very nice of you to remind us of that. I have often wondered how much data goes through for this but have never checked my data widget before and after a speed test.
    Senior Member shibby_nexusone's Avatar
    thanks for the info but i still have unlimited data
    Senior Member blackstar's Avatar
    Quote Originally Posted by shibby View Post
    exactly my thoughts...maybe for others this is helpful.
    Member uheenada's Avatar
    Quote Originally Posted by blackstar View Post
    Unlimited is not really unlimitied unfortunately.
    The carriers set a 'soft cap' at 2 or 5gb. Not that you can't use 3g after you reach the cap but the carriers will look into your account activities as why you used so much. Usually tethering will reach that point however.
    Thanks for the info, but who cares?
    Funny how people are so proud, isn't it.
    Maybe you didn't notice (I'm pretty sure that you wouldn't), but AT&T is changing their data plans for new customers. So this could be very important for SOME people.
    im up to date on there data restriction i said thanks for the info,i have unlimited data still but that dont mean i dont keep track of my usage.
data usage test
do speed tests use a lot of data
do speed tests use data
does speed test consume more data?
how much data does speedtest use
how much data does speedtest.net use
speed test consume your data
speed test data hog
speed test data usage
speed test uses a lot of data
speedtest cimsumption data
speedtest data usage
speedtest uses too much data
speedtest using too much data
speedtest.net data usage
