GPS doesn't work on roaming
This is a discussion on GPS doesn't work on roaming within the Nexus One forums, part of the Google Phones category; I am with a local wireless company - Cincinnati Bell - which has a deal with tmobile and uses their 3g connectivity. I went on ...
Thread: GPS doesn't work on roaming
    Member lilcapo2003's Avatar
    I am with a local wireless company - Cincinnati Bell - which has a deal with tmobile and uses their 3g connectivity. I went on vacation this week and when roaming came on I lost all data connectivity including use of my Gps. I thought the GPS was through a satellite not needing data connectivity. Anyways does anyone know of a way for GPS to work while roaming? Thanks
    Senior Member number 9's Avatar
    Quote Originally Posted by lilcapo2003 View Post
    When you say you lost GPS, do you mean you couldn't see your location in Google maps?
    Without a data connection, you won't be able to access Google maps since it uses data to download map info, even tho you still have your GPS on. There are third party apps on the market, like Copilot and Mapdroyd, that work offline with data stored on your SD card.
    Senior Member antikryst's Avatar
    looks like number 9 is right... you just dont have data while roaming. GPS isnt connected to the roaming function but it uses satellites to lock on.
    Android Lurker maris's Avatar
    Are you sure you had "Data Roaming" checked in settings? I've never had a problem while roaming.
    Member greg_nexusone's Avatar
    it takes longer to lock on since it can't make use of AGPS. Also make sure you have it enabled. I used mine abroad for a couple of months no problems.
    Yes, the gps still works fine for me even when I don't have data roaming. I had my map of my trip already downloaded, and even though I was without data for over half an hour (up by the white mountains in nh), the gps showed my position on the map the whole time. Granted, if I had tried to zoom into the map, I would have lost it all, but I didn't need to. I did have a voice roaming connection at the time, but it still worked even when I didn't have that, too.
    What is T-Mo's roaming policy? Does it ever cost extra money for calls or data? I heard a rumor it doesn't, but I've never seen confirmation of that (other than the fact I wasn't charged extra for any of the calls I made). I'm mainly wondering if it's dangerous to turn on the data roaming option.
    I'm hoping that by August there will be a decent navigation program available with saved maps as I'm hoping to go to Arizona, and I don't imagine there is much T-Mo out there by Tuba City.
    Quote Originally Posted by FlyingsCool View Post
    I have one of the unlimited plans and I have never been charged for roaming, and use it frequently.
android 5 roaming not working
android enable gps roaming
android gps doesn't work abroad
android gps not work in canada
android gps roaming
does data roaming affect gps
google maps doesnt work while roaming
gps doesnt work when roamung
gps not working on android in roaming
gps not working while roaming
gps while roaming virgin mobile
is gps part of roaming
roaming is on google doesnt wokr
why doesn't my gps work nexus 4
why google maps not working when roaming
