Frf72-frf83
This is a discussion on Frf72-frf83 within the Nexus One forums, part of the Google Phones category; here ya guys go. enjoy http://android.clients.google.com/pa...2.684bd56a.zip...
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: Frf72-frf83
    Junior Member mozzer138's Avatar
    Frf72-frf83
    cxm
    cxm is offline
    Senior Member cxm's Avatar
    anyone know if this is a file you can simply put over the existing frf72? I have seen another post about downgrading to 2.1 etc first which seems a bit convoluted - if there is a version that is as easy to do as the last few then I will be quite happy to upgrade...
    edit - forget this question, didn't look at the file name properly - it is the file for those already on frf73 and is updating now - thanks for this
    Senior Member flow's Avatar
    updated from frf72 to frf83.. great! Don't have to wait for ota
    cxm
    cxm is offline
    any swype users be aware that this breaks it again - just like last time a simple uninstall / reinstall fixes it
    Android Lurker BayRican's Avatar
    is it the same steps as last manual update?
    cxm
    cxm is offline
    yup - i used the same steps as for frf72
    So just rename file update.zip or leave it
    cxm
    cxm is offline
    exactly the same as last time - you need to rename it to update.zip
    Sorry that was a dumb question? Thank you very much
    Junior Member promethius's Avatar
    Talking
    Quote Originally Posted by mozzer138 View Post
    Yaay! You're the man mozzer. Saved us from bunch of downgrading
