froyo 2.2 browesr problems
This is a discussion on froyo 2.2 browesr problems within the Nexus One forums, part of the Google Phones category; ever sinc i updated i cant get on hppts site just wont load on 3g ok on wifi ? any idea guys driving me mad ...
Results 1 to 10 of 12
Thread: froyo 2.2 browesr problems
    Junior Member andyjames1985's Avatar
    ever sinc i updated i cant get on hppts site just wont load on 3g ok on wifi ? any idea guys driving me mad thanksin advance
    Junior Member jlishere's Avatar
    Hi,
    What website are trying to load on the browser?
    Does 3G otherwise work with other websites?
    Try to clear the data and cache for the Browser app in Settings / Applications / Manage applications / All / Clear data + Clear cache + Force stop - then, reload the browser and see if you have any luck.
    Also, just make sure that the "Data enabled" checkbox is marked in "Wireless & network settings" / Mobile networks.
    Let us know if you still have a problem.
    ok im getting http error 400 your browser sent a melformed request
    is your browser http/1.0 comploant? and a load more spill
    its on 3g only and only https pages im so lost cheers andy
    mah
    mah is offline
    Senior Member mah's Avatar
    It worked fine for me. I tried https://mail.google.com
    Member killerbender's Avatar
    probably there is an error with the security certification
    Junior Member wizact's Avatar
    3G https problem
    I have the same problem here in Malaysia. https is not working over 3G but it is OK over wireless. I cannot access to gmail or buzz over browser. I afraid it is because of mobile carrier.
    Member zippy's Avatar
    i had the same problem. I went into settings, then mobile networks and ticked data roaming. this cleared the problem for me.
    Hope it helps
    Member dlff's Avatar
    Wizact, may I know what mobile carrier are you using in Malaysia?
    Cheers mate!!
    Carrier
    It is Maxis. It worked before upgrading though... I tried with Opera... it works but it doesn't have location capability for buzz
    Carrier settings
    I read in won't navigate on native browser after update to froyo (it does on opera mini 5) - Android Help that if I delete proxy and port from AP settings it works and surprisingly it WORKS!!!!
    Thanks All
froyo tablet having browser and network problems
