No ring tone on incoming call
This is a discussion on No ring tone on incoming call within the Nexus One forums, part of the Google Phones category; I have the FRF91 build of Froyo and when I receive a call the ring tone does not play. The phone will ring once and ...
Thread: No ring tone on incoming call
    Junior Member chronopc's Avatar
    I have the FRF91 build of Froyo and when I receive a call the ring tone does not play. The phone will ring once and the notification light will light up once. Then it's just silence. Anyone knows how to fix this?
    62 times
    Need more info. Is this your actual cell number being called, or another (like Google Voice)? Do you have any intercepting apps running like visual voicemail,etc.? Is bluetooth enabled when this occurs?
    The problem occurs regardless of whether my cell number is called or google voice. The only thing I'm running is google voice.
    Sometimes the phone will ring once and vibrate once. Once that occurs, all calls after that will be silence. The screen and notification light will light up. But the ringtone does not ring and the phone does not vibrate.
    Junior Member hodedmonk's Avatar
    I was about to type "same problem" but it came to me like a cliched light bulb moment.
    Most of the ring tones on the Nexus are actually long files (5 to 15 seconds long) i had been using a mp3 of an old 1960's phone. the kind that rang in the principals office when your dad called. loud and annoying. but if you put one ring it wont repeat.
    Try taking your mp3/sample and doubling it a couple of times. (copy and paste to the end of itself) It will trigger once, bur\t sound like its repeating.
    Junior Member getsanju20's Avatar
    You have to check all the functions of your phone.I think some setting has been changed.
android no ringtone for some incoming calls
galaxy s4 no ringing on incoming call
no ring tone for some callers on android
phone does not ring for incoming calls samsung galaxy s6
phone does not ring on incoming call ringtone
phone not ringing for incoming calls android
s4 mini not ringing for incoming calls
s4 no ring tone
s4 not ringing incoming call
samsung 4 problem no ringtone on incoming calls
samsung android does not ring for incoming call
samsung s4 does not ring
samsung s4 not ringing
testing incoming calls ringer android phone
when samsung phone is dead does it ring once?
